This is a nice set of door panels. They are not warped much at all but are also nto 100% perfect like new. They are also almost 40 years old. Very presentable set. In case you didn't know, you can turn these in to power windows very easily. The hardboard backer of the manual panels has a pre-cut stamping in the back. All you have to do is knock that out and cut the vinyl. The manual crank is in the exact same location. You can see it in the pictures below. You would not be able to tell it was formerly a manual panel. The very bottom has some light splitting in the piece that wraps around but you can't see it when mounted and it would be easy to repair if it mattered that much. These are located in Charlotte, NC. $100+ shipping.
