want to add lighted rearview mirror to my 84 vert. have a mirror and harness from a 99 vert has any one done this
I did it. I have an 84 LX vert. I bought a lighted rear view from an 87. If you're not good with wiring have a mechanic you trust do it for you. it wasn't a hard thing to get done. My mechanic ran wires from the dash harness up through the A pillar rail up into the windshield header to the mirror. Just connect the wire that controls the door open/light on to the same wire that turns the kick panel lights on when the door opens. The other wire gets a constant 12V source for the map light feature so you can flip on the map light when the door is closed.
Funny but the rear view I bought had 3 wires and a rubber grommet and my vert has a slot that the grommet fit right into just above the windshield. even though my car didnt come with lighted rear view I think it was an option, thats why the slot was there for the wires and grommet.
is there a plug he went to or did he just splice the wires
LIFE IS ONE LONG WEEKEND
it was not a option in 84 only started in 86
did it plug in to the harness
It may not have been an option, but they knew it was going to be. Because my 84 vert with original interior had the slot for the grommet that holds the wires, as shown in the upper circled area.
The bottom of the wires to the rear view you will measure length, cut with enough slack to run down the A pillar into the dash on the driver side and splice one into the door switched kick panel lights wiring, the other into a constant 12v source for map lights, and then a ground. On the mirror's end you would do best to buy a used lighted rear view from another Mustang vert that has both ends of the harness plugs. that's what I did. As shown in the lower area circled in my photo.
if you're not good with auto electric, just find a good looking rear view that has both ends of the harness connector and let a mechanic you trust set it up. That's what i did and mine has been great ever since I put it in. I put natural LED's in the rear view and in the kick panels light sockets. My interior went from very dark to extremely lit up. If you go with bright LEDs its even brighter lighting.
This is the only pic I could find for now. One day this weekend when I have time I'll take a few better pics to make it clearer. You can see by my other post, the rear view lighting that I accidentally shorted when I screwed in the sun visors. Should give you a good idea of how to route the wires under the A pillar, around the sun visor assembly and through the windshield header panel.
Hey I found a pic of my mirror before I had it installed, so you can see I bought this with both male and female ends of the harness as part of the mirror. And the rubber grommet also was part of the assembly and I'm sure you will find a slot it will fit into perfectly.
HAD
HAVE
My '84 GT vert has it as well. Don't have the sticker but all the wiring looks factory and not modified. I also used a later mirror with double-switches as mine was missing when purchased.
Sounds like all you need is the wiring harness or at least that end plug at the mirror. Good luck, OB!
86 LX Coupe
Thanks guys for the help . I had hope of finding a factory plug to wire to. Since all our cars started off as coupes and coupes all had some sort of dome light . I am just hung up on not splicing wires. where did the coupes dome light plug into. thanks for the pics and all the help Kent glade you got your box of stuff.
Thanks guys, mine has the cut out as you can see in the picture. OB
