Results 1 to 8 of 8
    Default Cobra spare tire
    Does anyone know what size spare wheel is on an 98 cobra. also will it fit in spare tire well on my 84 GT vert?
    I know its a 17" wheel, but don't recall the actual tire size. The 17 is needed to clear the 13" front brakes. I believe the overall height is still @ 25.6" so you can use that to measure with to determine if it will fit your 84 GT vert. Good Luck!
    FEP Member T top 86's Avatar
    Nov 2017
    Dearborn heights
    This should help. Name:  20201213_195512.jpg
    Thanks winding down my 5 lug update just need to make sure before I buy a spare that clears my cobra brakes that it will fit in tire well. thanks again
    OB
    Tray do you have A Tom Gloy car
    It's 155/70/17 .
    https://www.corral.net/threads/cobra...e-size.547114/
    The one out of my 95 cobra is 155/70/17. TL
    https://www.ebay.com/itm/1994-2004-M...-/284097221585
    1994 - 2004 MUSTANG SVT COBRA SPARE TIRE 17" 155/70/r17
    155/70/17 = 25.5" diameter
    245/45/17 = 25.7" diameter
    (Less than 1% difference between the above. Note, those are ideal/typical sizes.)
    Good Luck!
    Thanks 25.5 will fit in the 84 vert spare well
    Aug 2004
    California
    Yes, but it will sit high - not a big deal but I still keep mine in the 86 vert.
