Ok guys I know the wiring is as follows below. My question is do I just toss the factory voltage regulator? I know the amp meter wont work anymore. I
-Green from alt to green to regulator
-Yellow from alt goes to yellow at regulator or to output post
-White gets looped at alternator
-Red at regulator gets capped.
-Replace wire from alt to starter relay with 4 gauge and fuse
I want to add a better ground. I thinking of changing the factory ground to 4g. Replacing the strap from trans to firewall with 4g. Should I add more? Maybe from each side of block to frame?
