Results 1 to 15 of 15
    Feb 2018
    Saskatchewan, Canada
    Default Heater core delete
    looking at deleting my heater core as this car will only be a nice weather driver and will be stored once it starts getting cold. Does a guy just plug the lines at the firewall with a U shape hose then connect lower water pump line to intake fitting, keeping the upper water pump line running to thermostat?
    Mustangs
    84.5 Gt T-top
    85 Gt
    Mar 2003
    Lowell, Oregon
    I think you'd go from bypass on the pump to the intake manifold?
    Coolant flows from the intake to the heater core and back in to the pump.
    You could just connect the ends of the hose together of course with an adapter, but I'd get that you'd have hoses under hood in that case for no purpose, but it makes it easy to hook back up if you decide to go out on a cool winter day that's dry.
    Just an opinion, but why not leave it connected, in case you're out cruising one evening and it gets cool enough that you'd like to use it?
    Feb 2018
    I think that's what I was talking about when I said lower pump line. Just didn't know it is called the bypass lol. As for why I'm not leaving it. I bought the car with the motor pulled so it was never connected in the first place. I've done a ton of work to this thing and I just want to get it running and driving first. Don't really care about heat as of now. Once the car is performing and half ass reliable I may want some heat in it but right now it's not a priority.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Mar 2003
    Lowell, Oregon
    I assume you have a non-AC car? Boatloads easier since the core is behind the glove box and not the dash!
    Feb 2018
    Nope it's a factory a/c car. Why would it matter though I'm not removing the actual core. Can't I Just want to plug lines and bypass it?
    Mustangs
    84.5 Gt T-top
    85 Gt
    Mar 2003
    Lowell, Oregon
    It doesn't in that case. If the motor is out, is the dash also out? If so a new one is a good idea, with a restrictor. Beats pulling the dash again in the future.
    If not, don't worry about it, but do install the restrictor if you hook it back up.
    Feb 2018
    Nope dash is still in. Ya when I'm ready I will order the lmr kit that comes with the restrictor. Thanks for the help!
    Mustangs
    84.5 Gt T-top
    85 Gt
    Mar 2003
    Lowell, Oregon
    Mar 2003
    Lowell, Oregon
    Just a thought - if you do bypass the core, I would put a pair of rubber caps over the ends of the core inlet/outlet pipes. Wouldn't want any critters taking up residence that become a blockage down the road if you hook it back up. Unless that's what you meant in your first post with a U-shaped hose.
    Feb 2018
    Yup that's what I meant. Another question I had was it seems like my outlets from my water pump are very close to me alternator bracket. The hose that will run from pump to thermostat seems fine bit the other one I'm not sure will fit without causing a kink in hose. I've watched videos and it shows a gap where the hose can run through but mine bracket is solid. Any thoughts? Here is a pick. Sorry for the small pic, I hope you can make it out. Board makes you edit picks heavily now.
    Attachment 134587
    Mustangs
    84.5 Gt T-top
    85 Gt
    They make rubber caps to go over the water pump nipples with a hose clamp. Probably 3/4" and 5/8".
    Feb 2018
    Pardon my ignorance but why would I cap them? Do I not have to still connect one to the thermostat housing and one to the intake?
    Mustangs
    84.5 Gt T-top
    85 Gt
    Mar 2003
    Lowell, Oregon
    I think he meant heater core pipes.
    I bought a generic elbow hose and ran it down under the bracket for my build. It means an extra splice, but that's better than a kink in the line.
    There are two fittings on the water pump and one fitting on the intake. The fitting on the intake is the coolant OUT of the engine and to the Heater Core. Of the two fittings on the water pump the Left fitting should be the IN for coolant returning from the Heater Core. The Right fitting should be the Bypass fitting that goes to the Thermostat Housing. If you are not running a heater core, you can simply cap the two fittings that would send and receive coolant to/from the heater core. You can also run a loop of hose between the two if you want. There is coolant pressure on the fitting of the intake and suction on the fitting on the water pump, but only up to the maximum rating of the radiator cap of @ 16lbs. So capping them is not an issue if using good quality rubber caps. I do recommend capping the heater core tubes also just in case. Hope that helps!
    Feb 2018
    Thanks Trey, ya that helps. I will just run the hose from the bypass on the water pump to the thermostat and cap the intake and the other water pump fitting as well as the fittings on the fire wall. Thanks everyone for all your help.
    Mustangs
    84.5 Gt T-top
    85 Gt
