Results 1 to 13 of 13
    Mar 2008
    darien il
    Default e7 heads on a 85 stang
    i have a stock 85 stang. i can get a set of e7 heads (62 cc) to replace my e5 heads (68 cc) and if i did the math correctly the CR should go from 8.4 to 9.0 . from what i can gather this should be a bolt on replacement. i would like to continue using regular gas ( it is a DD) and the main question is will i need to replace the pushrods?
    do not want to install rollers rockers or anything else. i get decent MPG and it is a nice running DD. hoping for a little better millage with higher compression. advice?
    Nov 2004
    Chas. SC
    I have had them on my '84 for about 8 years. Straight bolt on and I put 1.6 roller rockers on with them.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Mar 2003
    Lowell, Oregon
    Direct bolt on. Don't be afraid to clean up and slightly improve the heads first. Roller rockers are indeed an easy upgrade.
    Mar 2008
    darien il
    thanks for the feed back.
    from what i have found roller rockers help when the rpm's go north of 4k. with 330k on the motor i seldom go that high. and when you leave stock then you need machine work to convert to a stud. plus 200 (or so) for the rollers.
    i was thinking easy upgrade, one afternoon. but was wondering if i needed different pushrods. and of course a few ponies and better mpg.
    Mar 2003
    Lowell, Oregon
    Roller rockers reduce friction at every rpm.
    Not a needed upgrade of course.
    I think* pushrod length was the same but it is easy enough to check once the heads are on.
    I put some E7 heads on an 80 vintage 302 a few years back without too much trouble.
    You may want to consider picking up a set of Ford Performance shims for the stock rocker pedestals just in case you need to increase the rocker heights slightly. They are not too expensive and handy to have on hand if you need them.
    I found I had to shim all my rockers by 0.030 or so when I did the conversion but you really need to assemble your combo to see exactly where your at for lifter pre-load. I would guess it should be very close if your using a stock thickness replacement head gasket and the rockers off your previous motor etc.
    If the opposite is the case and your pushrods end up being too short then all you can do is order longer ones.
    Cheers
    The E7 heads are setup for a roller cam and roller lifters and will therefore have a lot more seat pressure
    The GT40 and GT40P heads found on explorers were also paired with a roller cam but that particular cam took a lot less seat pressure
    It might be fine but I’d at lease measure seat pressure and look into what a flat tappet HO cam is supposed to have
    Other option is always to go to Morrel linkbar roller lifters and a roller cam while you’re messing with stuff
    Good point about the potential difference in spring pressures (roller vs flat). Does the 85 have a roller cam ?
    In my case I did the roller conversion to a stock 95 HO cam with the retro linkbar lifters as well as the E7 heads as you mention. I also did the trickflow spring upgrade kit as well so had my bases covered essentially.
    From what I remember though the general consensus was that the stock springs were quite wimpy on all of these stock heads including the later E7 and GT40's as well etc.
    I suppose if there are concerns you could probably swap over the 85 springs onto the E7 heads. Not 100% sure but I think they would fit but may have to shim them too. However now the easy upgrade gets more complicated
    Jul 2010
    Houston (Clear Lake), Texas
    The 85 Mustang 302 was the first year of the roller cam and it did not have roller rockers...nor did any of the following year models. The E5 heads on the 85 are essentially the same head as an E7, and in fact were carried over to the early 87 302 power plants. The difference is the combustion chamber size, which varied through it's production from year to year.
    HAD
    HAVE
    Jul 2009
    Chicago, south subs
    Quote Originally Posted by bob85gt View Post
    No need to convert to studs for roller rockers. The Ford/Crane are bolt-down pedestal mount just like the stock stamped rockers. I just installed a set of pedestal mount 1.7:1 roller rockers on my 302. No other changes necessary except for shimming each rocker for correct preload.
    FEP Member Mgino757's Avatar
    Jan 2011
    Virginia Beach, VA
    If switching to E7 heads, I'd at least get the exhaust ports worked on. They flow like hot garbage with the huge thermactor bumps.
    Why not put a better set of heads on than the e7......you may not rven see a performance gain for all the work ....
    Stephen Johnson
    SS/D 427 Ford Fairlane NHRA-IHRA
    National Record Holder 9.49 @ 139mph
    1985 Mustang daily driver
    10.88mph 125mph N/A 337
    Mar 2008
    darien il
    Money- e7 would not cost much- bump the CR and hoping that would mean more HP and better MPG. trying to keep that balance of cost and power and gas mileage.
