Results 1 to 5 of 5
    Default Front Spring Isolators
    Can anyone tell where the long tubular shaped isolators pictured install at? The doughnut shaped isolators re easy to figure out, but I can't figure out where the tube shaped isolators would install at. Supposedly they are for the front springs. Thanks for any help/info you can provide.
    They go on the bottom of the front springs where they sit in the control arm.
    Thomas
    For rubber ones, they go on the bottom of the spring.
    For poly ones, they go in the trash.
    Unless, you believe in fairy dust, unicorns, or world piece.
    Then, smoke/eat what-ever you're on, and fly - fly far away from the hindrances of the real world. :-)
    Also, new poly isolators add ~~1/4" of height to the front. That's one way to tune the actual height and tire clearance.
    Good Luck!
    Mar 2003
    Lowell, Oregon
    Bottom of the front springs. Poly doesn't flex as much. A little silicone and a rubber mallet helped me installing them.
