Results 1 to 3 of 3
    Default 1984 GT350 body side molding ?
    Hello , I have a Canadian 1984 GT350 convertible. Usually , the body side molding on a GT350 are juste a small 1/2 red molding between the wheels. On my car . it has a full rubber white molding with a 1/2 red stripe in the middle like on normal Mustang GT . Is this a unique feature on Canadian car ? Have you ever seen full rubber side molding on an other GT350 ? Thanks
    Nov 2004
    Chas. SC
    I've got the thin red rubber stripe.
    American car.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    I have a US GT350 and it has the thick molding on the quarters, the bumper guard 1/2 inch bit between the tires. Do you seriously have the white molding all the way around? I can't even imagine what that would look like. Pictures?
