    Default 1983 Mustang GT Hood Scoop Nuts
    Can someone show or tell me what type of nuts were used on the 1983 hood scoop to attach it the hood? I know that the thread on the studs are 1/4-20.
    Thanks in advance, Mongos82ttop
    Should look pretty much like this.
    https://lmr.com/item/LRS-16630HDW/mu...dware-kit-7982
    1/4-20 nuts with a free spinning washer. Good Luck!
    Those look kinda like the hardware to attach the taillight housings
    Also parking light hardware, front fenders to bumper cover.
    Nuts are similar to flange nuts
    Careful when tightening. The studs can strip out of scoop.
    Cannot be replaced without taking off scoop due to stud flange position.
    Also easily stripped if nut is rusted to stud. Been there.
    Snug is good enough. Recommend a bit of anti sieze.
    More on this: search keywords 'hood scoop studs'
    I appreciate the replies guys.
    The hood scoop on my car has two different types of nuts securing it. Just wanted to make sure i put the correct ones back on it.
    Thanks again.
