If on a budget and looking for best bang for the buck, Explorer motor all day every day.
Throw in the stock mustang cam, 1.7's and enjoy.
Jeremiah
1986 Mustang GT 5spd, 3.27's
Aside from valve clearance, not sure what is so undesirable about the 86 (assuming you are replacing heads on an 87+anyway).
If you are going to spend money on another motor that is only going to have E7 heads, you could use that money for E7's
and a valve relief cutting tool. BTW, 86 pistons are forged, explorer motors are not.
https://www.stangnet.com/mustang-for...istons.644290/
Thanks for the reply. I just picked up an explorer motor and will get tore down for an inspection.
1986 Mustang GT
1984 Mustang SVO
OX1 — I agree about motor differences. Ultimately I wanted GT40 or 40p heads and could not find any at decent price. I found a 96 mountaineer motor with 102k miles and gt40p heads with intake included for under 4 bills. So, I will tear it down and see if it’s worth using and report back. Still may use the 86 block…
1986 Mustang GT
1984 Mustang SVO
