Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
    Thanks GR and Jack. I'm trying to catch up with you and am learning. Looks like my metering valve is blocking my LF output only which is strange as I would have thought the valve only shuts off front or rear not just one port. I agree it sounds like that LF is blocked with crud. Need to figure out how to clear that outlet or push back the metering valve so fluid will flow LF again. Will try the switch removal and see if I can get the shuttle to move. If it's free then I have to try it from the output in with a small screwdriver or pick and see if I can get any movement. On a side note my son picked up the drum brake tools for me today so I can deal with the drum adjustment when I get to it.
    Current FEP:
    Past FEP:
    Duplicate
    Current FEP:
    Past FEP:
