Results 1 to 12 of 12
    Default T-Roof Weatherstripping or Headliner first
    Hello all,
    My 83 GT needs both a headliner, and T-Roof weatherstripping.
    This is part of my winter projects.
    Which one should I do first, or does it matter.
    Also, I have seen where they just make the Headliner with the plastic backing.
    Is that hard to install? Does anyone just sell the vinyl headliner where I could just use the old headliner board, or is that not recommended.
    Thank you
    The headliner material wraps and glues over the metal roof edges on the TTop opening, and a piece pinches over all that to hold it in place. There's a video on LMR that shows the whole process.
    84 Capri RS Turbo
    USAF 1986-2007 (Ret)
    Do NOT buy the plastic backed headliner. Take your old one, strip the old material off of it, remove the old glue with a scotch pad and find the old Asian upholstery guy in your area who is better than everyone else even though he never advertises at all and have him recover it. The flippy, floppy plastic is a PITA and it just plain sucks.
    John Adams
    July 7, 1775
    Feb 2012
    Elizabethton, TN
    I can second this.
    Thank you all. I appreciate it
    So. SMS makes the headliner by itself. How many yard or yards would I need? Thanks
    Double check the measurement of the sunroof headliner backer board to verify. I generally buy 2 yards when doing a headliner, but that's not SMS original material pricing. I hate to be short or super close when doing it. I think 1.5 yards will complete the headliner, but again double check measurements and allow at least an extra 1" or more around all 4 sides. I think if you are extra careful you can do it with 1.5 yards, but again it won't save you that much over just buying 2 yards. Good Luck!
    Thank you Trey.
    SMS has the right material for the headliner, but they do not put foam backing on it. Has anyone successfully glued foam on the back of vinyl?
    Is it doable? Will it hold.
    So I have a similar question, my t top is missing the headliner but new weatherstripping. So am I going to have an issue trying to put a new headliner in
    Quote Originally Posted by 83GTTops View Post
    Thank you Trey.
    Pretty sure the vinyl headliners didn't have a foam backing on them. Only the cloth (Mouse Hair) headliner fabric did. I might be wrong, but every vinyl OEM headliner I have removed didn't leave any foam residue on the backer board when finished.
    That is my take also, no cushioning on the vinyl headliners, just the fabric ones (and I have done t-top, sunroof and solid roof cars).
    Ok, thank you for your answers and feedback. Here is why I wonder.
    I have a roll of Diamond Tier I bought awhile ago.
    Here is the roll.
    See how it has a foam back? Is is very thin.
    Here is the front from SMS, which is correct.
    Here is its back
    Maybe it will work just glued to the cardboard?
    The material you have will work just fine if you are good with it. Obviously it is not an exact match to the OEM, but most would never know or care. If you like it, I would use it and be done with it.
    Either will glue to the back board with no issues. I highly recommend the 3M Super 90 spray adhesive. Easy to find and works very well for this type of application. If you haven't done a headliner before, definitely watch some videos in regards to how to spray the adhesive properly and install the material without wrinkles, creases, etc. You only get one shot with the Super 90, so make it count! Good Luck!
