Results 1 to 10 of 10
    Default Another MSD Tach adapter question...
    Hey guys, I have a 86 GT here and I cannot get the stock tach to work.
    Simple combo. Holley term X. 6al. MSD 8920.
    Tach output on the box goes to white. Violet goes to c246 pin 12(dg/y)
    Ground is the stock ECU ground in the pass side kick. Fuse 18(hot in run/crank) kicks on the adapter.
    Msd tach output tests fine with aftermarket tach. I’ve tried 2 tach adapters-no change. I’ve tried different clusters. No change. Tach does not move. What am I missing here?
    86 Capri-84 LTD a wagon-85 notch-86 notch
    Oct 2017
    south-central WY
    Has the stock tach ever worked?
    I wasn’t 100% sure(I took the car apart for a customer right off the trailer) hence why I tried a known working cluster as well
    Well tried another adapter, another cluster and no success. Called msd tech support and they told me I can’t run a 6al
    Box with the stock cluster. So to anyone who’s accomplished this-the monopoly which is Holley Corp says you’re wrong. Lol.
    Mar 2015
    Rose Hill,Kansas
    Quote Originally Posted by Badsmurf View Post
    I am using msd 6al, coil, distributor and tach adapter and my stock tach works fine. Will post picks of adapter later.
    Same here, i have MSD 6AL, Coil and noise reducer , tach works fine. I'll also look and see what else is on there because I do believe it has some type of adaptor. Can't remember cause it's be a loooong time sine I've put that on my car.
    At this point I’ve tried the 8920 as well as the 8910 and zero luck
    Mar 2015
    Rose Hill,Kansas
    I am using the 8920, 6al, blaster 2 coil and correct distributor for 302. No problems.
    Oct 2017
    south-central WY
    What ECU are all of you running?
    Mar 2015
    Rose Hill,Kansas
    Quote Originally Posted by darkd0r View Post
    Went carb, no ecu
