Results 1 to 6 of 6
    Default Sway Bar Bracket
    For anyone that needs a set now there is an option.
    https://lmr.com/item/LRS-5486A/musta...brackets-82-93
    Awesome thanks
    And they replace the craptastic plastic nut plate with actual metal!
    Jack Hidley
    Feb 2012
    Mississauga Ontario, Canada
    Thanks for the link Trey. Coming from an industrial profession. I love the fact they used a solid steel mounting plate to thread into.
    Any idea which bushings will fit inside these? Thanks
    Works with factory and aftermarket bushings per the website.
    So any replacement bushings should work just fine as long as you specify 82-93. Just match the sway bar diameter and you will be good to go!
