Results 1 to 8 of 8
Thread: 1985 Gt
    Default 1985 Gt
    1985 Gt 27000 miles on the odometer
    Here is the door code
    VIN
    1FA = Ford vehicle manufactured in USA by Ford Motor Company
    B = active belts, no airbags
    P = passenger car
    28 = Mustang 3-door sedan (hatchback)
    M = H.O. 5.0L V8 engine
    8 = VIN check digit
    F = 1985 model year
    F = Dearborn Assembly
    189239 = 89,239th 1985 Ford scheduled for production at Dearborn Assembly
    Door Tag
    F0045 = 0045 lbs front accessory reserve load
    R0089 = 0089 lbs rear accessory reserve load
    Exterior Paint Colors - 2R = Bright Red
    DSO - 48 = Detroit district sales office
    Body - 61B = Mustang 3-door sedan (hatchback)
    Int Trim - PA = cloth Articulated Sport seating (P), Charcoal/Grey interior trim color (A)
    AC - 2 = Dark Charcoal hood stripe, Dark Charcoal Mustang GT decal on hatchback
    R - 4 = AM/FM stereo radio
    S - [blank] = no sunroof, no T-roof
    Ax - Z = 3.08:1 axle ratio, Traction-Lok (limited slip) differential
    Tr - 2 = Borg Warner T-5 5-speed overdrive manual transmission
    OO = front springs
    SS = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Thanks.
    It doesn't have A/C on the car. Is there a way for me to see if it was a foctory delete or if someone removed it?
    Dec 2006
    Middletown, DE
    Pretty sure AC was an option, so it wouldn’t be a factory delete option. Does the climate control panel in the dash have “AC” written on it?
    85 Mustang GT
    Early 83 was last time the AC code was on the door tag. You'll need the buck tag codes.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Picture of the firewall at the heater hose locations and I can tell you if it was Factory installed A/C or not.
    Can I send you my vin and you decode my car?
    Stephen Johnson
    SS/D 427 Ford Fairlane NHRA-IHRA
    National Record Holder 9.49 @ 139mph
    1985 Mustang daily driver
    10.88mph 125mph N/A 337
    Quote Originally Posted by 1Quik85GT View Post
    Start a new post with your info and we'll get it done.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
