Was looking on Facebook Marketplace and came across this. Description said bolt dropped into intake. I bet it made a hell of a racket when they started car up.
Screwed.
Not too shrewd.
well.... there's your problem
Past 4 eyes-
U.S. NAVY 1980-2009
DANG! I have been looking for that bolt!
Trey
They were edlbrock for a 302, a friens of mine said it might be possible to aluminium weld and resurface, not dure it's possible may cist more or nagging feeling when will weld let go.
If it is welded properly, It should never let go.
Ouch, yep thats ugly.
Judging by the corrosion alone looks like that head has more problems than just the screw issue.
been there done that! cracked my block # 6 cylinder back in my original 84 mustang back in 84. mine was a wood screw and I still dont know where it came from.
I had a nut fall into the carb on my 76 Capri. At first it was bouncing around by one of valves, randomly making the car run like crap. Eventually, the nut made it past the valve and cracked the piston, cylinder wall, and head. The nut was squished to less than half its thickness. I still have that nut on my key chain as a reminder of my bad mistakes.
79 Mustang Coupe - Jade Green Metallic - 5.0 5Sp - Purchased 2006
17 Mustang Convertible - Triple Yellow Tri-Coat - 3.7l Auto - Purchased 2020
01 Mustang - 3.8 Auto True Blue - Oct 2001- Apr 2022 RIP
85 ASC - McLaren 5.0 SC - ASC White - 5.0 CFI Auto - Owned 2004 - 2016
98 Mustang - White - 3.8 5pd - Owned 1998 - 2001
84 Mustang SSP - White - 5.0 5sp - Owned 1993 - 1998
84 SVO - Charcoal - 2.3t 5Sp - Owned 1989 -1992
79 Mustang Ghia - 5.0 Auto - Owned 1981 - 1986
68 Mustang Coupe - 302 Auto, Yellow - Owned 1980 - 1981
