Results 1 to 3 of 3
    New User
    Aug 2011
    Saint Matthews, South Carolina
    Default 1979 manual window regulator removal
    Greetings.
    I am wondering what all is involved in removal, refreshing, replacing guide bushings and reinstalling 79 manual window regulator. I did a search for a step by step procedure or some instructions on the process. just want to know what i'm getting into before i get started. Any tips, tricks, or what to look out for are welcomed.
    Nothing like the sound of a small block ford
    Four Eyed Fox Body Preserver
    Stock 1979 5.0 Currently Restoring
    83 Mustang A pure muscle streetfighter
    Regulator is riveted in.
    Per 79 Ford shop manual Body Vol 4 page 42-07-6:
    Remove panel, watershield, support glass in up position.
    Drill out regulator attaching rivets, 1/4" drill bit.
    Disengage regulator arm from glass bracket and remove regulator from door.
    Install:
    Position regulator in the door and insert the roller into the glass bracket channel.
    Position regulator to the inner panel. 1/4"-20 screw and washer or 1/4" rivet
    Use rivets or bolts with nuts to reinstall.
    Gloves are good. Metal edges in door frame, grime.
    New User
    Aug 2011
    Thanks for the info. Guess I'll get at it.
