Results 1 to 3 of 3
    Default No Wiring! Need Help
    Recently bought 84 Capri drag car. Want to convert to street car. Problem: previous owner removed all Headlight, taillight, running light, turn signal wiring. Is there a harness I can purchase? Where do I start? Help??
    Sent from my LGMP260 using Tapatalk
    LMR.
    Imho, just send them your check directly each week.
    LMR Rules!
    https://lmr.com/Product/Search?q=wiring
    Also, check ebay, You may get a good deal.
    Good Luck.
    The 84 wiring was crap to begin with. Major insulation degradation over time. Most have had major wiring repairs already if still on the road.
    Personally I would go with Ron Francis and have them build you one of their kits. Not a direct plug and play, but works very well, especially if you are taking a drag car and converting it back to a street car.
    This is the version I will be using on my 82 GT that is being built. Definitely not an original car in any way. https://www.ronfrancis.com/prodinfo.asp?number=AC%2D67
    I have one of their older kits in my 79 PC that was original the Turbo 4/4spd and is now a 5.0/5spd with Cobra IRS and brakes at all 4 corners. The new 24/7 is a better option for fitting into our Foxes, but wasn't available the 10+ years ago when I bought the kit for the 79 PC. Good Luck!
