Results 1 to 13 of 13
    Default Short Throw Shifter Recommendations
    Hello All!
    I recently bought an '83 GLX 5.0 in great condition with low mileage. It came with a Hurst Short Throw Shifter.
    Issue is, when I am in 3rd and 5th the shifter bumps into the radio dial.
    Can anyone make a good short throw shifter recommendation?
    Thanks for your help in advance!
    Jul 2010
    Houston (Clear Lake), Texas
    Have you checked to see if it's bolted up correctly?
    HAD
    HAVE
    How about changing shifter handle, that way you keep short throw, several aftermarket available.
    ed
    Portland Oregon
    I have a Steeda Tri-ax in my Saleen with the Steeda handle. I like it and the positioning. Unfortunately, the Hurst that came with my car wasn't doing it for me. I would try changing the handle and see if that solves your problem.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    May 2014
    Royal oak Mi
    Possibly missing the plastic shifter cup allowing it to travel further than normal
    I have a Hurst that came with the car and its non issue
    FEP Power Member David Claflin's Avatar
    Oct 2008
    Redneck Riviera, Fort Walton Beach Florida
    some guys have been known to bend shift lever to suit their height, seat position or whatever. I've got the hurst shifter in both of my cars and hitting the radio is not an issue.
    1985 LTD LX, Mach1 brakes, 17" Mopar police car wheels. 302, T5, 4.10s
    1986 FHP coupe, stock shortblock, TW heads, Holley SMII intake, 4.88, T5Z
    1990 Red LX, ported AFR heads, TFS-R box upper, weenie cam, 1 3/4 long accufabs, 3" exhaust, T5, 4.56
    Barboursville, WV
    Are you sure the shifter itself is aftermarket short-throw? Just wondering if maybe they just put the Hurst shifter arm on the stock shifter base.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Jan 2004
    Olathe, Kansas
    Ive never heard of an issue with the Hurst. Ive used a Steeda TRiax and loved it every time.
    Now stang-less.
    88 Cougar 5.0
    If the shifter lever bolts to base are loose, travel will be all over the place.
    Pull up the shifter boot and see whatcha got.
    Have a T-5 Core/Hurst Billet Plus base. Totally elated with it. Perfect gate positions for me.
    Ordered a custom tower base only, exactly per Core recommendation for long 10.5" Hurst lever and Ford T-5 trans.
    Reused the longer lever, boots, ball used with the stock T5 base. Bushing was fine.
    Longer stick than stock needed different fulcrum height to preserve the short throw from a new base.
    Very short throw with nice firm solid feel no slop. No adjustments needed. No noise.
    Shift ball position is a spread hand's width from the steering wheel rim and couple inches higher than stock.
    With thumb on steering wheel rim, can touch shift ball with little finger.
    This is a more natural position with no wrist bending shifting. Arm is level when shifting.
    Can shift with hand on ball, or wrist sideways, thumb on top of ball. A natural position to pull a lever.
    Is never anywhere near the dash, and elbow/arm easily clears console when shifting.
    T-handle shift 'knob' also works great. I switch up every now and then from ball style to the T.
    Can use shorter stock T-5 shift levers if bolt pattern is Hurst.
    Liked it so much, ordered short throw shifter kit for my Ranger. Same deal perfect (after adding 2" to stick height).
    stock T5 base (L) and custom ordered Core/Hurst (R)
    Name:  shifter core install (20) 3030.JPG
    Hurst lever used. Pic is before swap.
    Name:  shift Hurst 009 lever 3030.JPG
    First gear
    Name:  shifter core install 1st (42) 3030.JPG
    Neutral
    Name:  shifter core install N (43) 3030.JPG
    Second gear
    Name:  shifter core install 2nd (44) 3030.JPG
    For comparison, pics of lever positions prior to change. Same Hurst stick, boot, stock T-5 base.
    Note position of boot plate and boot folds:
    First gear:
    Name:  shifter515 1st (1) 3030.JPG
    Second gear:
    Name:  shifter515 2nd (2) 3030.JPG
    Feb 2018
    Saskatchewan, Canada
    Have not used one yet but have read really good things about MGW shifters. That's what I will be putting in mine when I'm ready.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Jul 2007
    Richmond, ME
    I will agree with all of this; the Hurst should fit without hitting anything, AND that the MGW setup is fantastic.
    I had a Hurst shifter and nothing to complain about, better than the (admittedly, worn-out) stock shifter. I'd buy another one.
    My SN95 (3.8 V6/T5) has an MGW shifter and it's so adjustable, I have it just as I like it, and MGW is at the top of my shifters list now. If I had a Hurst, I wouldn't replace it just for the MGW, but if I had to buy a new one, I'd need persuasion not to go with the MGW.
    As for the original poster, there must be something wrong with the install or the condition of the Hurst in there. Is it a Hurst, and not just the Hurst lever? Maybe it's the lever for a different car? Or, as mentioned above, the plastic cup--how much wobble is there in the shift lever before the gears start to engage?
    Had the shift lever loosen up once. Crazy sloppy. Thought the trans was bad.
    Drove into a parking lot, and pulled the boot off.
    One bolt had worked its way all the way out. Had tools and was back on my way.
    Changed out the two shift lever bolts for longer ones to add lock nuts.
