Results 1 to 7 of 7
    Default 85 GT rear quarter body molding color?
    What's the paint code for gray molding on the 85gt? Is there a spray paint code or will I have to have some mixed up? My car is medium canyon red with the gray molding trim...thanks
    Stephen Johnson
    SS/D 427 Ford Fairlane NHRA-IHRA
    National Record Holder 9.49 @ 139mph
    1985 Mustang daily driver
    10.88mph 125mph N/A 337
    Jul 2010
    Houston (Clear Lake), Texas
    No there is not a paint code from Ford. You can get an SEM product that is close...still a bit light...but it's also an interior and not exterior paint. If you search I came up with a mix through Sherwin Williams automotive that's more of a commercial grade product utilized by Budweiser, Coke, etc. It's kind of expensive but it's been 8 or so years now and it still looks like the day I picked it up from the paint shop.
    HAD
    HAVE
    SEM 39153 is the exterior bumper trim coating
    SEM 15303 is the interior trim coating
    thank you
    Stephen Johnson
    Turns out looking good.. Do you guys clear coat it?
    Stephen Johnson
    Generally the SEM trim paint is one and done. I personally do all my trim in BC/CC for longer durability. You can clear coat if you wish. Just make sure to use a Satin or Matte clear coat spray. Anything else will be too glossy and will not look correct or original. Good Luck!
    I ended up putting 3 coats on and I don't think it will need clear coat...it may stand out to much . Thanks
    Stephen Johnson
