Ok after fixing most of the CFI system issues (with lots of help from this forum, thank you) The car ran pretty good. (New fuel pump and fuel pump relay).
Well now the car seems to not get power to the fuel pump. turn key on and you do not hear the fuel pump. Car turns over just fine just not getting fuel. I can some times fiddle with the fuel pump relay wiring plug or swap out the relay with another one and the car will sometimes start and run for a few. But I slam a door or the hood and it dies.
I think I have a short or grounded out wire somewhere under the drivers seat. Next step is to pull the driver seat and see if I can find anything. Unless you guys can think of something.
Is there anyway to just run a hot wire straight to the fuel pump to get the car running?
