Ford calls it front frame stabilzer rod. The two behind it are rear frame stab rods.
Front= E3ZX-5C024-AC, rear= E3ZX-5C025AA.
Fronts connect K-member to rad support, rears connect K-member to floor pan gusset plates.
Found on convertibles and in M-5024-A Chassis Stiffening Kit.
If lucky, may find a used parts yard that has an 80's Mustang convertible.
Nothing special. Light steel tubing, flattened ends with drilled bolt holes.
May have to make or have one made. Would not be hard once tubing is found. Cut, flatten the ends, drill.
Its like steel tubing used on old backyard swing sets for bracing.
- You may not post replies
- You may not edit your posts
Forum Rules
