Results 1 to 10 of 10
    Mar 2003
    Lowell, Oregon
    Default Transmission X-member - that sucks
    My last build was an '83. This '81 Granada has been great in some ways (it had a quadrant set up and not direct pull clutch) but I had no idea you needed a narrow version of the double hump to run a T5. I got one from a guy that was wider where it mounts to the body. Just found out today after installing the trans. Ordered a Stifflers unit from LMR, but in the meantime a jack stand is playing trans support...
    I keep learning new things for the earliest years of these cars.
    Jul 2009
    Chicago, south subs
    You can just cut the mounting tubes down to fit and reinstall the bushings.
    Barboursville, WV
    I'm usually the guy that likes modifying what I have to make it work. But after going with the Stifflers crossmember on my pace car, I don't think I'll ever use a stock one again.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Mar 2003
    Lowell, Oregon
    I actually thought about just cutting the tubes down, but I don't have a good way to do that. So I either pay someone to modify an old part, or spend a few bucks on a new step get prettier one.
    Those old rubber bushings were pretty squishy anyway compared to my 'Vert mounts and poly trans bushing.
    Yep, I cut mine too. 10 years, no problems. You can do it with a Sawzall.
    Mar 2003
    Lowell, Oregon
    I do have a sawzall. Chose the new pretty route though.
    IIRC, the stifflers x member can be outfitted with a driveshaft loop.
    Mar 2003
    Lowell, Oregon
    It can, yes, but am not using one.
    It will be a fun street car.
    Will be interesting to see how it installs. I bought one for my car. I went to install it, and I will have to cut the sleeves down.
    I will be running a 4r70w, so I need to have the trans in the car to figure out how much to cut off. (fore/aft)
    It looks like a quality piece though.
    Mine’s a street car too, but I would like to take to the track at least once to see how she does
    Mar 2003
    Lowell, Oregon
    The only anti-their directions thing for me:
    For a T5 with a poly bushing they say to use the two included spacers.
    With no spacers used my shifter base about rubs the top of the trans tunnel.
    So, no spacers for me.
    Ironic since I will have to use spacers to 'drop' my front antisway bar frame mounts because the bar hits the oil pan.
