Results 1 to 3 of 3
    Default Radio not powering up
    I had a new radio installed a few weeks ago and everything was fine . Fast forward to the other day and i took interior out because of water leak. Now radio will not come on.. Does center console wiring have anything to do with radio? I did clean up some wiring too under there so maybe something came loose. Was working fine the other day.
    FEP Member 0F0 CBR's Avatar
    Feb 2019
    Ontario, Canada
    Check the fuses? The fuse panel, and sometimes there is a fuse on the back of the stereo as well.
    Ok. I checked the fuse at radio. Seems ok. Have yet to look at panel. I forgot to mention that battery went dead also and i had it charging with key in ignition and accessories on. Not sure if that did anything.
