I sourced a stock SVO boost gauge for my GT Turbo. What is the vacuum source for the gauge on the SVO? Which vacuum ports / type work in the GT?
I did the same. It looks like it just connects to the vacuum tree.
In the svo we have a black with red stripe vacuum hose under the dash to tap into. But that hose comes off the vacuum tree on the fire wall.
That said, the 1st thing svo owners learn is DO NOT trust the factory gauge. Mine has been off as much as 5psi.
1982 Capri RS 5.0L
