    Default Vibration / Not Moving
    I’m having a problem with my GT Turbo driveline. There are times when i try to take off from a stop i get a strange vibration. The car feels like its trying to move but the brakes are locked. The brakes are not locked so i think it’s a driveline thing. Sometimes it actually stalls the car. Once moving it feels like I’m driving on square wheels. Any idea what would cause this? I’ve also had trouble down shifting into first unless I’m at a dead stop. HELP!
    Barboursville, WV
    Check your pinion and see if it's loose. Better yet, pull the cover and check to see if pinion gear is contacting your carrier. That will cause a pretty bad bind. Marks on the carrier should be very noticeable, if that's the case.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Very worn universal joints on the driveshaft as well.
    W
    Thanks for the responses. I have a direction to go in.
    Quote Originally Posted by WilliamCapri View Post
    I had this happen on my 86 GT, thought the trans was falling out.
    84 Capri RS Turbo
    USAF 1986-2007 (Ret)
