Hello
I am going to be replacing brake lines and fittings on my 79 Zephyr
My question is-
from the master cylinder There are 2 lines to the prop valve. I am assuming that the rearmost line is the front brakes, and the front most line is the rear brakes?
I have the stock master here and that is what it looks like, but I had to cut the lines and use a socket on the stock fittings.
Is there a diagram somewhere that shows which lines go where?
i still have the original lines, so can figure that out. Looks like most fittings are 3/8-24 but the pass side front brake line has 7/16-24 fittings that exit the back of the prop valve and also 7/16-24 at the pass side caliper brake hose?
Any feedback is welcome, thanks guys this site is great!
