Alright, I need some help with identifying and connecting the 12v switched ignition (stays hot when you hit the starter) wire for my Holley Sniper EFI system, Hyperspark system and electric fan setup up. My car is a 79 302 mustang (pace car if it matters). I am not an expert at electrical work but make out the wiring diagrams provide in the forums. I guess enough to be dangerous and screw something up.
1st question: I think I have identified the correct wire but I want a second opinion. The wire I identified was 32 R-LB which runs to the ignition module. Is this correct?
2nd question: I have one wire from the sniper and hyperspark system and two for each of the electric fans. When connecting to the 12v ignition signal can I connect them all to the same wire and the same connection?
Thanks for the support. I create a nice write up and share once i get it all finished.
