Results 1 to 9 of 9
Thread: Coolant Pipes
    Default Coolant Pipes
    Has anyone come up with a source, or replacement ideas for all of these coolant “pipes” around the turbo engines? Would stainless steel work for replacements with coolant? Looking for something I shouldn’t have to replace again 😃😄
    Thanks!
    Apr 2009
    Acworth, GA
    This comes up a lot, getting used ones is your best bet now unless you want to remove them altogether.
    Several people remove the ones that go around the back of the block, remove the oil warmer, then connect the intake to the sensor location on the driver's side of the block. That sensor can be moved into the intake with a T.
    Big R Motorsports sells the lines then that connect the water pump and thermostat to the heater core.
    I have a working set on my Capri so I haven't done this, I'm only repeating what I've read about.
    There was a supplier making stainless steel tubes for the 86 svo. I believe he stopped and someone else was looking into making them. I would take a look over at svocop.com
    Aug 2003
    Villa Park, IL
    Forced4 was having them made, which were really nice replacement in SS, but they went under several years ago. I have a set minus one pipe. Also have some nice stock pipes.
    Quote Originally Posted by MIKE'SVO86 View Post
    Are you looking to part with any? I was thinking about having someone local remake them.
    Aug 2003
    Villa Park, IL
    I sent you a PM. I can send you pics of what they look like. Mike
    Mike, which piece don't you have? I need a water feed into the turbo on my car, mine kinked when I was removing it.
    84 Capri RS Turbo
    USAF 1986-2007 (Ret)
    Aug 2003
    Villa Park, IL
    Bill -
    I'll send you a pic of all of the pipes I have. I have several stock duplicates.
    Never heard of an oil warmer?? Are you referring to the oil cooler sandwich between the block and oil filter.
    1979 Ford Mustang Pace Car
    4.6 2V conversion underway!!
