Results 1 to 7 of 7
    Default Signs your Serpentine belt tensioner is wearing out?
    Anyone ever had the spring on that tensioner wear out? I had a bad alt bearing, and a bad idler pulley, but it still gives a little squeal up over 4k. Is that the spring not holding the idler down with appropriate pressure?
    Mar 2003
    Lowell, Oregon
    Some have the little range indicator lines, but I think that mainly detects belt stretch.
    With a belt mounted see how much deflection is there. Too much could indicate a weak tensioner spring.
    Nov 2004
    Chas. SC
    Normally they start bouncing with the enginr running, or if it sits a while it tends to stick in position...
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    It is a wear item just like most under hood parts. Not unusual for something like this due to age and mileage. They are pretty sturdy and last a long time, but they will wear out over time. Generally aren't too expensive to replace even when needed.
    I will need a replacement belt tensioner for my 79 5.0 but have never seen them for sale. Where are they available?
    Quote Originally Posted by Webstang View Post
    Rockauto for one.
    Dave
    1FABP28M4FF114537 bought 12/84 sold 1992
    1MEBP79M8FF613099 bought 9/13 sold 10/19
    1FABP28M4FF166315 bought 3/12 sold 5/21
    1FABP28T7FF239068 bought 10/14
    1FABP28T9GF181465 bought 10/14
    Barboursville, WV
    I used to buy them at the parts stores. Seems like I had several go out during my 3 decades of driving these old Fords.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
