Results 1 to 8 of 8
Thread: Firewall pads
    Default Firewall pads
    I am replacing the carpet in my 85 RS. I am going to prep the floor boards ext. I notice on both the drivers and passengers side firewall the is a large rubber with padding mat. How do you remove and should I put them back in?
    Can you take a picture for us?
    Sent from my SM-G950U1 using Tapatalk
    Here
    Sent from my SM-N960U using Tapatalk
    1965 Mustang
    1983 Capri L 5.0
    Present
    1985 Capri RS
    2011 Ford CVPI
    My car came to me without them but they make sense to me. Hopefully someone on here has more information!
    That is the firewall insulation pad. It will go all the way to the bottom of the windshield and completely across the width of the dash. It is there to lessen engine noise, vibration, and provide additional insulation to help with HVAC. Personally I would keep it and reinstall. You can add additional sound deadening "Dynomat" if you like and some remove it entirely and replace with only the newer style sound deadening in some cases. Unless yours is rotten, destroyed, or doused in mice/rat urine and feces I would keep it. Good Luck!
    I was planning on keeping it as it is in good shape. I wanted to remove it in the time being as It is kinda in the way of my floor prepping. I guess I will lift it up so I can get behind it as far as I can.
    Thanks for the info.
    1965 Mustang
    1983 Capri L 5.0
    Present
    1985 Capri RS
    2011 Ford CVPI
    Mine smelled terrible of mouse piss so I threw it away.
    someone sells a replacement for the stocker but it’s kind of expensive.
    Apr 2009
    Acworth, GA
    Also know that you can't easily remove it. between the steering column mount and the HVAC being on top of it, there is a ton to remove just to get to it. If it doesn't smell I'd leave it alone.
