Results 1 to 9 of 9
    Default No longer for sale-1983 GL 5.0L, 5 speed, Teal, T-Top hatch
    Putting it in storage. Not a good year to try to sell a classic car. I'll try again in the spring.
    In Olmsted Falls, Ohio, west side of Cleveland. Odometer reads 124k, engine has less than 2k. Asking $6300 (read - $6k, firm). Details below. PM me for phone number.
    I bought this back in college, many years ago, from a high school friend. It went from daily driver to garage furniture to project car. Time to let it go though, as I am on to another project. I'd really like this car to have a home where someone likes the 4-eye Mustangs, so no better place than here to post it.
    Original T-5 manual transmission, converted 8.8” 3.27-1 rear end, 5 lug conversion and brake upgrade - ’95 spindles with ’01 front disk brakes, ’88 T-bird Turbo coupe rear disk brakes & Ranger axles.
    Full-length, welded subframe connectors.
    Custom rear suspension – fabricated lower control arms, torque arm, watt’s link
    BBK specific rate springs – 650#/in front, 260 #/in rear, Bilstein struts and shocks, adjustable camber plates and sway bar end links. Poly bushings front and rear. Swaybars – stock front, rear from ’92 GT.
    “Bullitt” steering rack with Maximum Motorsports solid steering shaft joint.
    Sherwin Williams teal, with silver accents and stainless lower panels.
    Centerline Zenith 5-lug wheels
    Firestone Firehawk Indy 500 225/50R16 (May, 2017)
    Upgraded headlights, LED marker lights.
    Dual AGM, low-mass batteries with disconnect.
    Covercraft all-weather cover
    1988 Mustang 5.0 short-block; rebuilt by Bill Klein of North Olmsted, OH (2010, currently <2k miles)
    0.030” over-bore, stock stroke, Keith Black hypereutectic pistons, reconditioned stock rods & crank. ARP rod bolts. 6 quart oil pan, windage tray, high volume oil pump.
    Crane cams Powermax 2030
    Intake: 0.533 lift, 270 duration
    Exhaust : 0.544 lift, 278 duration
    @ 0.050 lift
    Intake opens 1 BTDC, closes 35 ABDC, max lift 107 ATDC, dur. 216
    Exhaust opens 47 BBDC, closes 7 BTDC, max lift 117 BTDC, dur 220
    1990 E7TE heads – stock valves with 3-angle valve job.
    Gasket matched and home-ported (runner and bowl area).
    Ford Motorsport full roller rockers, 1.6 ratio.
    Crane Cams matched spring set (6500 rpm valve float)
    Compression ratio ~10 to 1.
    Weiand stealth 8020 intake manifold.
    Hedman Torque-Step headers, with Swain ceramic coating (inside and out).
    Custom stainless full length dual exhaust:
    3”-2.5” reducers, 2.5” catalytics, X-pipe, Corsa straight-through canister mufflers.
    MSD distributor.
    Set @ 15 deg. baseline advance. 20 deg. mechanical advance (35 total) @ 3000 rpm.
    MSD 6AL ignition box, 5800 rpm cut-off.
    Full accessories:
    High volume mechanical water pump. (195 deg. thermostat) Aftermarket aluminum radiator, “Cougar” dual electric fans, hood vents.
    Power steering pump, 2G Gen2 Ford / Mustang 75 amp alternator.
    No air conditioning. Auto-Meter tach. Relocated shifter handle on Hurst.
    Holley 650 CFM Street HP, mechanical secondaries. Tuned at CRT, Norwalk, OH, August, 2018. 235 WHP (243 corrected), 278 lbs/ft (288 corrected).
    Areas that need attention – Engine needs a rear main seal (leaks), clutch holds fine but is old, should be upgraded to 10.5” (flywheel available). Some body rust – at windshield header and on hatch lid – solid underneath. No rear speakers for radio.
    Many original parts provided with the car.Name:  Front Cropped.JPG
Size:  334.4 KBName:  Rear Cropped.JPG
Size:  261.7 KBName:  Engine Cropped.JPG
Size:  325.1 KBName:  Interior Pass Front Cropped.JPG
    Last edited by Bman83GL; 09-19-2020 at 11:46 AM. Reason: Putting car away for winter.
    83GL with '88 302. Project car for street / autocross / open track events.
    SB by Bill Klein, N. O., OH: (~10-1), Crane 2030, E7TE ported heads, 1.6 roller rockers, Stealth w stock carb rejetted 0.062 p, 0.070 s, 6.5" PV, MSD dist Mech advance only; headers, 2.5" duals - CRT-tuned: 246 HP & 275 #/ft
    T-5, ’95 spindles w/ ’02 brakes, 8.8” 3.27 rear, ’88 T-bird TC brakes & 5-lug axles. Fabricated rear LCAs, TA, Watt’s. BBK springs, TRX front bar, '88 rear bar.
    Sep 2010
    Lexington, MA
    GL Hatchbacks are VERY uncommon. Hadn't seen one in about 30 years.
    It's the unusual combination of GT/5.0L driveline with an "upscale?" interior. It had the TRX wheels and tires when I got it. Those hockey pucks are long gone.
    FEP Power Member 86-TC/SVO's Avatar
    Aug 2010
    Connellsville, Pa
    My first car was an 83 Mustang GL Hatch with 4spd w/overdrive 2.3. It had the sport interior (netted halo headrest) which I thought was odd.
    86' SVO 1C # 17 of 3379 86's #6475 of 9837
    86' SVO 1C #497 of 3379 86's #6955 of 9837
    84' GT Turbo #4 of 3241 GT Turbo HB's #560 of 3935
    87' Thunderbird TC 1 of 10
    Changed asking price to $7500.
    I really like that color!
    I push my fingers into my eyes......
    Update - 2023 - Looking to buy 81 Mustang, 82/85/86 Mustang GT, and 79 - 86 Capri (No Sunroof). Not looking for all original/show cars or convertibles - I will be modifying. Would be nice if both were - Black Interior, PW, PL, AC, No - or very little rust. Motor/Trans/Axle not important. Options negotiable with price.
    Thank you. Between the teal paint, stainless cladding and Centerline wheels, it turns heads. Particularly when I downshift with the Corsa mufflers. :-)
    Updated asking price - $6750.
    Updated asking price. I'd like to move this into a good new home while there are some nice driving days left.
