I was trying to do my homework on what is required to upgrade the small 10" front brakes on my 80 to an OEM type 11" brake (87-93 5.0). I need to stay 4 lugs so my 16" TRX will still fit.
I know you need to find spindles from a 87-93 V8 car along with the 11" rotors, calipers, bearings, and hoses. I pulled a set of spindles off a junkyard car and my thoughts were to just buy all the consumable parts or maybe a kit to do the same etc.
Questions - I ran across some information that says you can use 84-86 SVO caliper & pads on the 11" rotor for the (87-93) as an upgrade to those years. Is it this simple or is it more involved than that and is it that much better etc? I also assume my TRX rims will fit this 11" setup.
I know people have upgraded many different ways on this site and probably know all the ins and outs. Comments/suggestions are welcome.
