Results 1 to 14 of 14
Thread: 1985 ltd lx
    Default 1985 ltd lx
    Finally getting rid of my 1985 LTD LX
    It has a stock 85 non roller 5.0 H.O. with low miles.
    There’s a remanufactured Holley 600 CFM carb on a stock 4v Ford dual plane manifold with BBK shorties and some Mac Pro Dump mufflers.
    I ran a stock Duraspark ignition system with a MSD Blaster 3 coil, the distributor is brand new.
    I did a 5 speed conversion with the trans tunnel hump out of a fox Mustang, new Summit Racing clutch kit, and a WC T5.
    The trans has a lot of miles on it but it shifts and feels good.
    The rear end is original, it works great but should be upgraded to a 8.8.
    The interior is in great condition with no major wear. The headliner has a few dents and is sagging a little in the back RH corner.
    The body is great from 10 feet away!
    Up close it has some small scratches and a few dents. It has some rust on the rear upper corners on the trunk on the body. They were sealed but it needs to be treated again and resealed.
    Things that don’t work:
    Air conditioning
    Cruise control
    Rear RH power window
    Speedometer
    There is no smog equipment installed. Is being sold as is.
    It’s located in Berkeley, CA
    $6000
    MikeName:  Adjustments.jpg
    Body damage
    Rust in trunk corners
    Headliner and ripped sun visor
    The body and rear end have about 250,000 miles on them. I’m unaware of the actual mileage on this car as I swapped the speedo a few times in the past 10 years that I’ve owned the car. The front control arms were replaced about 40,000 miles ago. It also has the bigger 87-93 GT front brake conversion with good brakes/drilled and slotted rotors. I can’t think of anything else free to ask any questions.
    Cool car should sell quick!
    82 Mercury Capri - 11.99 @ 112, AFR headed Mountaineer motor
    86 Mustang LX Coupe - the original Coyote swap 4-eye. Gone but not forgotten!
    I'm open to offers, this is a really nice LTD that's ready for your built-up powertrain swap
    Default 1985 ltd lx
    PM sent.
    Thank you,
    Jim
    Bump, The LTD LX is still for sale.
    Still available?
    FEP User
    Aug 2013
    Lawrence Swamp. Amherst, MA
    if sold plez mark so...
    Chad
    Seeking: fox station wagon int/ext trim (esp LTD/Marquis)
    Retire/restore ol Bronk to daughter
    chrlsful@aol.com
