Results 1 to 25 of 34
    May 2014
    Royal oak Mi
    Default Best soap after greasy suspension work for hands and arms .what do you use
    tried a few heavy duty cleaners including industrial walnut types from work but at home swapping parts around and you need a good hand soap what do you use..
    Above average type of work say rear end swap and gear oil is on you and or control arm swap
    Wife calls you in for dinner grab garden hose and what soap
    Gojo suppro max is my new favorite
    Wd-40 works pretty decent
    Transmission fluid works incredible
    Tork wipes work ok if you need to get some of the heavy first layer off
    What have you found thats worth the money
    Fast orange eh
    Lava soap eh
    Borax powder decent but mess
    Cintas heavy duty is decent but not great
    I usually wear nitrile gloves and then wash up with hot water & dish soap. If I was working with gear oil
    Nov 2004
    Chas. SC
    Dawn with a surgical scrub brush.....
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    May 2014
    Royal oak Mi
    Working with gloves is tuff for me but makes quite a bit of difference for clean up
    Dawn is a engineering masterpiece by the chemical people
    Mar 2015
    Rose Hill,Kansas
    Gloves, then I use Dawn dish soap with a blue scrubby.
    For REALLY nasty hands and arms, I use Castrol Super Clean or Purple Power. I know, that stuff's caustic, but I scrub and rinse pretty quickly. That gets the majority of it off quickly, then I use a less aggressive one. Kinda stings if left on too long.
    84 Capri RS Turbo
    USAF 1986-2007 (Ret)
    Sometimes I add salt to the dishsoap for an abrasive
    also have a brush for the nails
    May 2014
    Royal oak Mi
    Cherry bomb i think its called is very gritty but pretty weak
    There's this green paste we use at work ill see if I can get the name off of it that could be used with or without water
    Its better with water though and it has chunks of pumice
    Nov 2004
    Chas. SC
    The "Go-To" for hands in the distant past was Go-Jo. Not sure if they still make it but its what most heavy production work bathrooms and garages used.
    Albert Einstein
    Almost "Stock"
    I like Fast Orange waterless hand cleaner. It has abrasives and lanolin. Rinses off with water pretty well.
    W
    Lightbulb Custom Mix
    Here's what I use for almost everything (car parts & greasy hands etc) and works extremely well . . .
    Mixture of:
    • 60% Glass Cleaner (Windex etc)
    • 20% Purple Degreaser (SuperClean etc)
    • 20% Dawn dishsoap
    I mix all 3 very well, let the foam/suds settle for a little while, then use a funnel to pour it into a spray bottle. Really works awesome. It gets sprayed directly onto parts to degrease pretty much everything. Now & then (but rarely) I might need something additional but this mix does mostly all and is pretty safe for finishes too.
    For my hands, I put the same exact mix in a "foaming" pump bottle kept by the sink to wash my hands with after I've done some really dirty greasy work. I always use a good hand scrub brush though it isn't always needed.
    For standard daily handwashing, I use the same style foaming pump bottle with 80% Windex + 20% Dawn and is the perfect handsoap.
    With either mix, it ends up being way cheaper & more effective than using only store-bought soaps by themselves. No "fumes" or "posionous gasses" either BTW. We buy 1-gallon sizes of all 3 soaps so it's bulk priced and can use plenty. Using a spray bottle or a foaming pump conserves usage too and is plenty strong to clean almost anything I get myself into.
    I do keep one large bottle of Zep "Cherry Bomb" Industrial Hand Cleaner (contains grit/abrasives) by the sink for the occassional time I need to deep-scour stained skin etc.
    I got to experimenting with different soaps because I worked in industrial heavy-labor construction most of my life around the filthiest equipment & extreme conditions - plus have worked on my own cars/trucks and house/property etc since my teens - I've tried to be society-independent & a DIYer, as much as possible anyway. Among other things, I used to clean/degrease/pressure-wash etc all kinds of heavy construction equipment and found that mixing up the above ingredients seemed to be effective 90% of the time to get me clean at night. But I suppose "results may vary" and there's always some goop or glop that's particularly stubborn! Some really bad greases & tars require a petroleum-based degreaser first, followed by water-based degreasers/soaps etc.
    #1) 1985 Mercury Capri 5.0L 4V 5-Speed T-Roof Motorsport Grand Prix IV
    #2) 1985 Mercury Capri 5.0L 4V 5-Speed T-Roof
    "Tolerance and apathy are the last virtues of a dying society" - Aristotle
    Jul 2004
    Montebello, CA
    I use LAVA soap for really thick grease on my hands (where ever) then Dawn soap
    Past 4 eyes-
    U.S. NAVY 1980-2009
    I like Luster Sheen but it’s not easy to find, my local hardware store usually has it.
    I use gasoline..jk..
    Sent from my LG-M327 using Tapatalk
    82 Capri BM, 84 Mustang Gt, 88 T-Bird TC, 93 Mustang
    Jul 2009
    Montreal, Quebec, Canada
    You might laugh but I use shampoo. The stuff is kade to clean hair grease and seriously cleans your hands.
    1985 Mustang Canadian Cobra
    It ain't Pretty but it doesn't care
    Quote Originally Posted by Killingcivics View Post
    I'll try that next time.
    Nov 2004
    Chas. SC
    Best way to cut gear lube is using Dawn. Nut you better use a conditioner of some kind because it will take the hair oil along wiht the gear lube. I always thoughtt the womans adverts with dry straw hair were fake... LOL
    Albert Einstein
    Almost "Stock"
    Jul 2009
    You find out things when your soap doesn't cut it.
    First round is what ever is handy depending on what I’m doing next. For the second round and deep cleaning, I use shampoo and a small scrub brush while in the shower.
    Head and shoulders always works for me. Easy off works too but is bad for skin and paint, on parts its magic. Spray agitate and rinse.
    My big thing is getting diesel and gas smell out of my skin.
    Nov 2004
    Chas. SC
    Quote Originally Posted by D3vst8r96gt View Post
    Only thing I found that works for Diesel is to overpower it with another scent. Then you smell like a bouquet all evening... LOL
    Albert Einstein
    Almost "Stock"
    When working at the dealer, asked mechanics how they kept their hands 'clean'.
    Parts washing, clean supply of cotton shop rags.
    Cream colored Go Jo in the can was common.
    Plastic shopping bags can clean wheel bearing grease off hands enough for finish with soap.
    Cleans grease off spindles too.
    Wiping hands in grass or even dirt works to knock the grime down.
    Smell? Does beer work?
    Boraxo paste
    Walnut cleaner (Nut Job brand from work)
    Go-Jo green citrus
    Lava soap bars
    Green Scotch Brite pad
    Rubbing alcohol
    various hand brushes
    bathroom mirror to get the hidden back of the arm elbow
    one sharp young single girl coworker i ate lunch with had a dirt spot still on the back of her arm the next day.
    I pointed it out as a flaw and ribbed her. Lisa appreciated it working for her best interest and mine.
    May 2014
    Royal oak Mi
    Good input thanks everyone
    FEP Member T top 86's Avatar
    Nov 2017
    Dearborn heights
    There is a hand cleaner that keystone automotive (lkq) has called key magic. Best hand cleaner I've ever used an doesnt dry your hands outName:  20201005_095714.jpg
    Cleaning hands with soaps or solvents.
    Acetone cleans well. Most solvents are flammable and defat skin, making it harder to clean later.
    Removing the heavy grease gobs down to soap level. Newspaper? Ha try and find some.
    Walnut based Zep, Jacks (smelly). Combo of soap and solvent. Citrus cleaners can work too.
    Cherry type smell like dipped cigars.
    Have used sandpaper, dry wall sanding screen to scrape paint off skin.
    As mentioned before, shop workers kept hands fairly clean by washing parts in solvents during course of workday.
    Mineral spirits, Safety Clean parts cleaner.
    The cleaner orange rags retain solvent for quick wipes. Nice to have a cleaning service for them.
    I hang or pile mine outside and let the weather clean the real greasy ones over time.
    1,1,1-Trichloroethane or regular was used up to the 80's where i worked to clean dies and parts.
    One worker cleaned his dentures in it.
    Washed many times at work in a classic round brown Terrazzo fountain sink.
    Had the step-on hose valves that worked 1/2 the time and cheap yellow powder soap you had to push the button for.
    Most of it washed down the drain unused.
