What are the preferred sn95 spindles for a k member swap? Getting a package with a arms bump steer kit and cc plates. 79 Fairmont I'm wanting to change to 5 lug and use sn95 parts.
Thanks Nolan
Sent from my SAMSUNG-SM-G920A using Tapatalk
Thanks Nolan
Maximum Motorsports recommends the 96-04 spindles for their K member setup and 94/95 for OEM K member. All of that is due to the location of the rack and pinion unit. What aftermarket K member are you installing?
Trey
I am running 94-95 spindles with my Team Z k member with 1” shorter control arms.
With offset rack bushings and bump steer kit, fits great and keeps the stock track width.
the later sn95 spindles will push the wheels out more.
I havnt bought one yet but was looking at the UPR kit that has coilovers a arms bump steer kit and c.c. plates. I'd like to stay away from 94-95 Spindles if possible just to save some expense, but will go that route if needed. I have a local wrecking yard that has a 95 I could harvest from but I have to pull and it's been so hot lately.
