Results 1 to 10 of 10
    New User
    Jul 2020
    West Palm Beach, Florida
    Default Marchal 750 Fog Lights
    I need to remove the lens and looking for the best way to accomplish this.
    Dec 2006
    Middletown, DE
    Have you taken apart the housing yet?
    85 Mustang GT
    New User
    Jul 2020
    Quote Originally Posted by tbirdman View Post
    Yes, it's all apart. The frame has a little too much rust but I have a good frame w/o a lens. Bottom line is I need to transfer the glass (lens) from the rusted frame to the good frame to properly restore it.
    Dec 2006
    Middletown, DE
    They lenses aren't glued in or anything like that, so they should come out pretty easily. I have an old one in the basement that I can take a look at when I get home.
    85 Mustang GT
    Dec 2006
    Middletown, DE
    So I checked the spare Marchal fog light that I have. Once you take the two screws out at the front of the light, the front frame will pull off the rear housing. I took the screws out of the frame and the lens just popped out from the front. There is a thin piece of weatherstrip that runs around the inside perimeter of the lens to keep water out and the two plastic screw standoffs, but everything is loose inside the frame. Here is a picture (looking at the lens from the back)...
    If the lens is stuck in the frame, either someone glued it in there, or there is rust buildup inside the frame that is preventing the lens from coming out.
    85 Mustang GT
    New User
    Jul 2020
    Thanks very much for your help. The weatherstrip on mine is very tight and not too interested in budging. I tried to carefully pry it loose. Probably rust as you suggest. I'll have another look at it. Sure don't wanna break the lens. Does the ws look like just common caulk or something special? Just thinking of what to use when resealing the lens. Thanks again for your time and help.
    Nov 2004
    Chas. SC
    If the gasket is that hard it will probably be unusable. with that said i would try some type of solvent IE.. acetone, toluene, gasoline etc and soak it a bit. that shuold soften and loosen the gasket.
    Note: use all safety precautions while using chemicals. gasket will then be destroyed so plan on buying/making a new one.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    New User
    Jul 2020
    Thanks. Very time consuming removing the lenses, even with solvents. Mostly accomplished by removing the sealing gasket piece by piece. I removed 2 lens and all I can say is be very careful with the lenses. One slip with a tool and it's bye bye lens. They don't appreciate being even very slightly, inadvertently tapped. Ask me how I know.
    What I don't understand is Tbirdman's comment about the lens coming right out. I do know that these 750's were manufactured in both France and Belguim and that they were slightly different regarding the usage and type of some of the innard parts. Mine were made in Belguim and I can tell you that the lenses were not made to come out easily due to the sealing gasket.
    Anyway, anyone know where I can get a nice 750 lens.
    New User
    Jul 2020
    tbirdman, I replied to your PM twice but neither is showing in my sent PM's. I'm new to this forum so perhaps there is a delay for PM's to show. You can email me at:
    jud149@bellsouth.net
