Results 1 to 4 of 4
    Barboursville, WV
    Default Rear glass rubber moulding?
    I have a couple hatches that are in need of some replacement moulding... the metal strip that covers the edge of the glass. Evidently, this moulding isn't being reproduced and most of the used stuff is in pretty bad shape.
    Has anyone ever swapped it for a soft rubber seal... something like what is used on some auto glass? Basically, you apply the rubber around the glass before installing it. When you set the glass, the rubber overlaps the sheet metal. Just thinking it may be an option and curious if anyone has done it already.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    FEP Member dk5_cobra's Avatar
    Feb 2011
    Vero Beach, Florida, United States
    I like the idea. basically making it look more modern like flush mounted glass
    Devin
    1979 Mustang Cobra - IRS, MM Suspension, 302/t5
    Check out my build thread for tons of IRS info, and general restoration help. There's a little bit of everything -->goo.gl/krmqNz
    Pm's welcome if you have any questions
    Barboursville, WV
    Quote Originally Posted by dk5_cobra View Post
    True. But I'm not even sure it would even be that noticeable. My 88gt was missing this moulding altogether and I sorta forgot about it. It didn't really stand out that much.
    I am sure you could make something work if needed. One issue is that the glass is not flush with the surrounding metal as is the case with most late model glass. Also the depth of the channel around the glass may be a bit shallow for the rubber trim to get a good set. You can always give it a try and see how it looks. I have considered it too, but luckily I have enough spare mouldings that I just use them.
