Results 1 to 2 of 2
    Default Best thing to wire for power aftermarket radio to in 1983 mark 6
    I’m struggling to find something to wire the power to for my after market radio in my 1983 Lincoln continental mark 6 anything will help thank you
    I often use the tap a fuse adapter https://www.amazon.com/Pixnor-Circui.../dp/B011I9QZX2 that plugged into the fuse panel with either ignition only or constant power is usually all it takes. Hopefully that helps. Good Luck!
