Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 102
  1. #51
    Jul 2005
    Medicine Hat, Alberta,Canada
    Far-and-away, the cleanest Third Gen floorpans, I've ever seen. i.e. cars that were DD-ed at one time.
    It does have a couple hairline cracks that will need to be addressed on the drivers side eventually. Typical V8...
    Sent from my LG-H873 using Tapatalk
  2. #52
    Jul 2005
    wow thats looking great, love that red! when you do the rims try jacking that corner off the ground so the wheel can rotate. get some of those things that look like green scrubbers that you can put into a drill (I cant think of the name of those things) spin the wheel while using the drill to get a nice shine
    I will definitely need to try something. The other 2 wheels are in very nice condition with minor use. The clear is very nice. I am debating on going stock BSW or RWL tires.
  3. #53
    Jul 2005
    Marti Report came today. I'm a bit surprised at the low number.
  4. #54
    Jul 2005
    Well I had to step up in tire size from 205/70R14 to 215/7014 because nothing was available in Canada. The original weights were still on the two wheels with the original tires on them. The weights had the "FORD" script on the out side and on the inside it had the Ford oval and script. I've never seen weights like this. I'll update with some photos once the tires are mounted and balanced.
  5. #55
    Sep 2010
    Lexington, MA
    Quote Originally Posted by Blainer View Post
    Good choice. I bought a set of Goodyears, about 20 years ago, same size. Pinstripe whitewalls even (could flip-in if not needed). Handled real nice, soft ride, but decent handling. These were purchased for use on my '69 Mustang, but on a Fox, even better
  6. #56
    Jul 2005
    Good to know. I'm glad I went with them
  7. #57
    Jul 2005
    Here are the Ford weights. Pretty neat.Name:  20200725_182104~2.jpg
  8. #58
    Sep 2010
    Lexington, MA
    Yes, I actually had the same Ford-scripted weights with mine. Evidently they were to 'counter' the weight of the Theft Lugs. (I have a set of NOS theft lugs for the 16 hole rims, too!!)
  9. #59
    Jul 2005
    Nice!
  10. #60
    Jul 2005
    Took off the front wheels to clean before getting the new tires put on. Noticed a green "X" on both wheels.
    Took the steel wheels off the rear. The drums have never been removed and still had the drum lock washer still installed. The passenger wheel seal has a good leak. I cleaned it up as good as possible. I will tackle that later in the revival process. The driver's side drum was rusted on really tight. Took over 30 min soaking periodically with WD-40. Sorry no pics of the gooey mess on the passenger side.
Size:  51.0 KBName:  20200731_193304.jpg
  11. #61
    Jul 2005
    Had some time when waiting for my tires to get installed so I finished up priming and painting the black trim on the rear window and drivers side. Turned out great using the same Duplicolor primer and Duplicolor black trim and bumper paint.
Size:  42.6 KBName:  20200731_185114_HDR.jpg
    Here is a sneak peak on the BFG 215/70R14. I could have went a bit wider on the back and the front was perfect with a finger space between the strut.
  12. #62
    Sep 2010
    Lexington, MA
    RWL's look so good with 16-hole alloys. Tint would look so perfect on that! (The quality type, not that 'purple bubbly' stuff). Would help preserve the interior, and contrast beautifully against the White paint
  13. #63
    Jul 2005
    Thanks. I'm not installing the aftermarket louvers again so I may tint in the future.
  14. #64
    Jul 2005
    Inside the drivers door is as clean as the passenger side.
    New weatherstripping, run channels and dew wipe installed.
    I never got the glove compartment items from the original owner but I got a box full of all the books for 1983. The box still has the postage from 1983 on it.
  15. #65
    Jul 2005
    Interior pics with some new carpeted floor mats.
Size:  30.0 KBName:  20200801_172037_HDR.jpg
  16. #66
    And the difference between pearlescent and iridescent is Blainer's!
  17. #67
    Jul 2004
    Montebello, CA
    again.... just love it!
    Past 4 eyes-
    U.S. NAVY 1980-2009
  18. #68
    Jul 2005
    White lettering tires are on. I absolutely love the look on these wheels.Name:  20200804_170819_HDR.jpg
Size:  53.4 KBName:  20200804_170837_HDR.jpg
  19. #69
    Jul 2005
    Peanuts anyone? Time for valve cover gaskets. Fel-Pro permadry to the rescue!
    Driver's side been leaking for a while. Original cork gasket came out in one piece!
    Carefully cleaned and preserved the decals and painted marks.
  20. #70
    Wowza! that valve cover came out nice! Great job.
    John Adams
    July 7, 1775
  21. #71
    Jul 2005
    Passenger side valve cover came off nicely but was uber dirty with oil and caked on dirt. Came out almost as nice as the driver's side.
    "OK" stamp stayed in place and Decal cleaned up not too bad
    I maybe at a crossroad when it comes to exhaust later. The heat riser tubes have rusted around the bolts and are loose now. I tried to loosen one of the bolts but as it was coming out, the head snapped off. So either I removed the riser tube and shield from both sides or I put a nice header and dual exhaust setup. Downside is I take away from the originality.
  22. #72
    What about a set of '85 headers with the heat risers? They are a direct bolt on and keep the valve. Best option at this point to me.
    John Adams
    July 7, 1775
  23. #73
    Jul 2005
    If I could find a nice set I had ight go that route.
  24. #74
    I believe Erratic50 has a set that came off his Saleen Clone. I think he took those back to Nebraska with him. Not sure if he had plans for them or not. Shoot him a PM and maybe you can work something out. Good Luck!
  25. #75
    Jul 2005
    Might have to
    I'm not sure if 85 has that small hole for that metal line that connects to the choke.
