Page 1 of 5 123 ... LastLast
Results 1 to 25 of 102
    Jul 2005
    Medicine Hat, Alberta,Canada
    Default Blainer's Barn Find.
    As some of you know from Facebook, I recently located a 1983 GT Mustang with only 76,000kms. The downside is it was left under a pine tree with a tarp on it. The tarp and rear louvers saved the near showroom fresh interior. The exterior got harsh sunlight and weather for at least 10 or more years. There is also a healthy dent on the passenger fender. Under the car is insanely clean with the original cats and y-pipe still on. The muffler and original tip is long gone. I have started to buff the baked exterior along with some removal of some items to find all the pine needles. They are everywhere!!
    Sent from my LG-H873 using Tapatalk
    -Current owner of a one owner(I'm now the second) 1983 GT 5.0 with only 47000 miles.
    Jul 2005
    Here are some undercarriage photos. Clearly reflects the low kms.
    She is a beauty! Nice find.
    Jan 2004
    Olathe, Kansas
    That interior is crazy clean!
    Now stang-less.
    88 Cougar 5.0
    Wow... Beautiful car... Great find....
    You got real lucky there! Nice find!
    Jul 2005
    Would anyone recommend rebuilding the original radiator or replacing it with a certain brand?
    The original owner saved the cowl from debris by putting in this metal screen.
    Here are some of the original tags for FoxChassis. No build sheet on drivers side floor pan. Gotta look in a few other spots.
Size:  14.1 KBName:  20200705_123022.jpg
Size:  21.1 KBName:  20200705_123046.jpg
    Jul 2005
    Upon arriving home, I noticed dripping fuel from the front of the carb. The 37 year old gaskets need to be pitched and a rebuild will be in the works. All original tags and marking I documented.
Size:  66.0 KBName:  20200705_131111.jpg
Size:  48.9 KBName:  20200705_131125.jpg
Size:  57.7 KBName:  20200705_131137.jpg
Size:  38.3 KBName:  20200705_140026.jpg
    FEP Power Member Bryan Knebworth's Avatar
    Sep 2010
    Lexington, MA
    Congrats Blainer, cool find
    The Buildsheet you are looking for will be found under the RH interior trim panel.
    Jul 2005
    Thanks Bryan! I need to remove them next before removing the sagging headliner.
    Nice find! I really dig those front wheels. Always wanted a set. I second that you will find the build sheet on the passenger side quarter plastic.
    Jan 2006
    Western MA
    Congrats on the new ride.
    1986 SVO Mustang - 1C
    Jul 2005
    It was one of those cars that you just can't leave in distress.
    That is a really nice car!
    good for you
    79 Zephyr, 4v/4r70w swap planned, with team z front and rear suspension, 8.8 and upgraded brakes and coil overs.
    Jul 2005
    Got the correct size battery for it today and I had some new cables made as the negative was so brittle, the outside casing was falling off. They will suit it fine for moving it around and starting it if need be. Next is an order to rock auto and get the rad rebuilt. Name:  20200706_172824_HDR.jpg
    Jul 2004
    Montebello, CA
    DAMMMMMMMMMMMMMMNNNNN! that sweet! get that under side sprayed to get that light rust stopped stunning
    2017 Mustang ECO BOOST (DD) 1986 Capri 5.0 Silver/Red
    1969 Falcon XW GTHO coupe (SOLD) went to australia
    Past 4 eyes-
    U.S. NAVY 1980-2009
    Jul 2005
    Quote Originally Posted by BLUECRAPI View Post
    I got the other 2 wheels as well. They still have the original Michelin tires still on them. Lots of grip but cracked and weather checked.
    I've never seen these matching hubcaps before. They were used for the rear winter tires.
    Mar 2015
    Rose Hill,Kansas
    I run a mishimoto two row radiator, engine is 363, never overheats. Radiator drops right in using stock parts.
    The hubcaps are really cool. I agree I too have never seen them. Classic rare sweetness!
    Jul 2005
    Good to know. I might just see about redoing my radiator first when the time comes. I just ripped out the interior for the headliner then found out when it was taken to the area where I picked it up, the guy left the window open a bit on the driver's side causing water to pool behind the driver's seat pan. So i took the carpet out to dry it out. Its been just over a day of drying and vacuuming the water out and it's just lightly damp. The floors are insanely clean mimicking the low millage.
    Jul 2005
    No build sheet that I can see. Interior is almost all out now.
    Jul 2005
    They may rattle and wear grooves on trim, bit they help keep alot of sun out of the rear interior. The original louvers that were on the car.
    Here is the trim I will need to replace. You can see the grooves that were wore into the metal trim.
    Nice car. first owner missed out on the best of a great car.
    Jul 2005
    I wish he would have kept in a garage too. He probably parked it after this happened.
    I hope I can save the fender.Name:  20200705_123200.jpg
    There's a paintless dent repair guy here in Omaha that would make fast work of that one. Unreal the stuff he's done.
