Results 1 to 10 of 10
    Mar 2003
    Lowell, Oregon
    Default Dumb question probably about heater core hoses
    I searched and didn't find it.
    Stupid me forgot: Heater core has a 5/8 and a 3/4 pipe. Which goes to the intake and which to the water pump? I know the restrictor goes in the small one (inlet) and I *assume* that goes to the water pump?
    Tried looking on line and didn't find what I needed. Not always good at that...
    It's a factory non-AC car. You know, the ones that changing out the heater core is a comparable breeze...
    No, the restrictor goes in the one coming off the intake manifold. That's the pressure side of the HC.
    Mar 2003
    Lowell, Oregon
    Got it, thanks. I couldn't remember which (intake or pump) sent pressured water to the core.
    The larger 3/4" pipe on the core then plumbs to the water pump. Intake manifold to 5/8" heater core inlet (on the left if looking at it from the front) gets the restrictor.
    I Just stuck a nut in the hose with a clamp to hold it steady....cux that's what i had around
    Mar 2003
    Lowell, Oregon
    Intake manifold to core inlet (3/4" at firewall) with restrictor, water pump to 5/8" outlet of core.
    Why did I always think the inlet was smaller than the outlet? No wonder these were known to go through heater cores
    For anyone that ever develops a leak in the heater core & wants to bypass it until replacement can be done or do it during summer months,& if your model uses a metal coolant pipe assembly (like present on 86-93 Foxbodys) or similar with the same ID pipes (3/4" 5/8") Napa sells a U shaped bypass hose which has the correct ID size for each of the two hose ends.This beats trying to rig something up,since each hose end is made to fit the pipes exactly.
    The part number is 10743.
    Napa's listing for the ID of each hose end is 19mm & 16mm, which is the same as 3/4" & 5/8".
    I've always had a theory that if you put the hoses on a heater core backwards it would hold up better. Essentially that's a lot of what a flow restriction does at the end of the day. Only then it is 3/8" inlet, 5/8" outlet..... not 5/8 inlet, 3/4 outlet like you'd get if you flip/flopped the lines.
    really stupid design. GM has used a valve under the hood that's ran by vacuum for years to keep the heater core out of the water flow path when the heater isn't on. One of the few things that was done better in that era.
    I've had a 90 degree elbow hooking the two hoses together on my 86 ever since the last time I popped a heater core on it. That makes like core #6 or 7. Damn they suck to change so I've been avoiding it for the past 5 years.
    The design is faulty for sure. My most recent heater core held up for less than a day after I swapped to a Typhoon intake and the motor saw a few 6150 full powershifts. Aggravating - I had an SSP flow restrictor in it at the time. Thought for sure I blew it up when the antifreeze went everywhere. A few months later the power steering return line did a similar thing -- again I thought for sure she was a gonner because one foot was on the gas pedal on floor and the other was on the clutch grabbing gear past redline when it let go.
    An underdrive crank pulley and a Cobra style waterpump pulley slows down the PS pump quite a bit and the waterpump some .... just to 1:1 .... but together it helps keep things from letting go so often.
    We accidently hooked up the heater core backwards one time on my Dad's 90 Mustang, and the heater barely blew warm at all.
    Matt
    Mar 2003
    Lowell, Oregon
    That is my one concern as the restrictor has a tiny hole. I have never used a restrictor before.
    Jul 2005
    Medicine Hat, Alberta,Canada
    I noticed LMR kit with the restrictor too. They have a good YouTube video on it. I've never put one in either. It's so the heater core doesn't get over pressurized.
    Sent from my LG-H873 using Tapatalk
