Results 1 to 4 of 4
    Default 85 302 ring sizes
    Anybody know what size rings came in the 85 302 HO? Is it the metric size like the 87-93?
    Jul 2010
    Houston (Clear Lake), Texas
    I think they are more like the earlier models...except forged and not cast...basically a flat top with four valve reliefs. Rings should be 5/64", 5/64", and 3/16"...
    HAD
    HAVE
    Ok thanks.
    The manual trans, carbureted engines for sure used the metric low tension ruing pack. I own one and went out and grabbed a piston and micrometer, measured the ring thickness and came up with 1.5mm, 1.5mm, and 3mm.
