    Default New to us 85 mustang - brakes question
    My 17 year old son bought himself a rather ragged 85 mustang to fix up. 5 spd with blown clutch (nothing left of the dusk), built 302, 2 sets of good t-tops but otherwise beat to death.
    I’ve had 7 fox body mustangs, rebuilt 2 engines, replaced countless transmissions, so I’m not clueless. But this one has me stumped.
    under passenger side rocker are 2 hard lines. One is for sure a brake line. The other is cut. Fuel lines run from drivers side down the center tunnel, so it’s not those. Anyone have a clue what the 2nd hard lines under passenger rocker is?
    thanks
    Chris in Cartersville GA
    85 mustang T-tops
    steeda Tri-ax
    interior removed
    long tube headers
    flowmaster exhaust with electric cut outs
    subframe connectors
    in progress
    new clutch, flywheel, cable, quadrant and firewall adjuster
    all new fasteners trans to crank
    degreasing everything
    front & rear brakes
    MSD 6-al2 replacing duraspark box working with stock dizzy
    door hinge pins with new strikers
    relocate battery to rear
    Barboursville, WV
    You sure someone didn't run new fuel lines? The one along the passenger side should be the original, I believe. Someone correct me if I'm wrong. 85 was an odd year and I'm not as familiar with them.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    I think that 2nd line may be for the fuel tank vent/charcoal canister.
    '85 GT
    My vote would be fuel tank vent line also.
    Thomas
    You all are correct. I traced it down to fuel tank vent line. I’ll reroute it and vent it somewhere safe.
