Glad you got it figured out
I would never thought the ignition switch could cause so many problems. Heater fan works now too.
Well a lot of circuit’s power goes through the ignition switch. Basically anything key hot which is a lot.
i think the battery hot stuff goes through the headlight switch mostly.
at least that is the way it is on my car.
I had to replace both switches on my car due to a leaking cowl before I bought it.
