Results 1 to 25 of 25
    Default Oil pressure and oil temp gauge
    Anyone know of a good option? Both in one would be awesome and both coming off the same sensor would be even better. And the win would go to that place being the existing pressure port.
    I did a search, and it seems like there are more dual purpose gauges available in the UK, but they don’t read PSI and Fahrenheit.
    Makes sense since their dashboards are smaller.
    Also found a nice looking gauge for airplanes, again makes sense with limited cockpit space
    was just a quick search, might find something on eBay or similar
    Doesn’t seem like a lot of ppl make the dual purpose gauges for cheap money.
    They are out there but they seem to be expensive IMHO
    May 2016
    Lake City Pa 16423
    That's an aircraft instrument.
    Dec 2013
    Connecticut
    A company in Uncasville CT ,Faria Beede Instruments, makes many for marine and other uses.
    Here is a link to one of their pages showing a multi function gage.
    https://fariabeede.com/2-pages/aftermarket.php
    View the Euro line.
    In the 60's as Thomas Faria they were making the tachs for the Comets and Falcon Sprints
    We have serviced few of their bezel stamping presses.
    Because they are for marine applications ,maybe pricey.
    Ray
    65 Galaxie 500 XL 390 auto
    2A
    Yes it is.
    I said it was in my post.
    Airplanes have engines too lol
    I kind of dig the aircraft gauge. Innovate makes an oil temp and pressure gauge in one. None of the two in one gauges I saw while searching were less than $200.
    '97 Thunderbird
    Yeah, that is kind of what I have been seeing. 200 dollar gauge but all the same sad mucking with a second hookup for temp. I don't want to drill my oil pan!
    Just trying to find an oil temp gauge is not easy. Wow. Seems like something people would be more interested in.
    Picking up the temp from the standard pressure port will not give you an accurate reading. The oil to the gauge is held in the same spot since it does not recirculate. Thus your temp will be slow to heat, slow to cool down. You will want to plumb into your pan for a temp gauge.
    Just my thoughts.
    Kenny
    Yeah, pretty much what I figured. Would be nice if there were just a port sitting around on the return to the pan I could plug into.
    Jan 2004
    Olathe, Kansas
    Why wouldn't a tranny fluid temp gauge work? There are a crap ton of them.
    Now stang-less.
    88 Cougar 5.0
    I can't see why even a temp gauge wouldn't work, they normally go near 280.
    You should be able to run the oil pressure gauge off the factory port just above the oil filter. If you need both the OEM gauge and aftermarket, then add a T fitting to run both gauges. I have done this in the past without issue. Then you should be able to use the fitting in the oil pan to run the temperature gauge sending unit if you have an aftermarket pan. If you are still running the OEM oil pan, then I have seen some use adapters to install a temperature sending unit in the drain plug fitting. Not the best for long term durability due to removal for oil changes, but it does work. Good luck!
    Interesting! I do have my aftermarket oil pressure on a t now from the OEM port. I was wondering if they made drain plug adapters. I really just want to see if it is within a good range then remove it so that might be my best move.
    Just purchased a drain plug temp sensor and a simple gauge from speedway. Hopefully will have it going this weekend.
    Well, installed it today, I have to say it is pretty nice and responsive. Shuttling around town and out in the countryside the oil was between 180 and 200. Kick it down and it rapidly increases in temp up to about 210 and the cools down back to 185 or so. Took it on the highway for maybe 6 miles of 70mph, still the same, heated up rapidly on the on ramp acceleration (220ish) then cooled rapid to 185 again. Got off the highway and watched oil temp rise up to almost 225 while puttering around town. Took it about 10 minutes to get back down to 185 again. The coolant temp gauge didn't move the whole time. I have movies but not sure it is worth posting them.Name:  IMG_20200626_154229.jpg
    I will say the drain plug sensor is very responsive.
    Here are the movies
    The first is climbing a 600 ft hill (you don't have to watch all 2 minutes)
    https://youtu.be/C6-ONSM2NVk
    The second is after 6 miles of 70 on the interstate.
    https://youtu.be/KznxuxC5_e8
    And the last is after driving through town at under 30 for ten minutes.
    https://youtu.be/KGnM2XtdsE4
    The last two videos are at a stop, idling at 550.
    Jan 2004
    Olathe, Kansas
    I was surprised to see how quickly the oil temps changed.
    Now stang-less.
    88 Cougar 5.0
    I am surprised it is not a more common gauge.
    Jan 2003
    lansing, mi
    I have a VDO brand I had to make an adapter for the sender to fit the front sump drain plug hole in my 7qt pan. I have to drive for a long time on a hot day before it even moves with a 160° thermostat and 2qts more 10w30. I think the hottest I have seen it get in that spot is 120°, maybe 140°. I realize it's not really a great place for it, but I'm not crazy about the sender or the wire terminal for it. It's like one of those old temp senders GM phased out with the round disc and the female spade terminals that slides over it and doesn't clip on very tight. That Classic Industries sender looks way better than what I have going on, if that is compatible with a VDO gauge I'd rather run that. Hmm...
    Cale
    It was pretty inexpensive, might be worth a try. The sender is low profile too, I was worried it would hang below the k member but it does not.
    wear at 160 degrees gets out of hand. You may want to consider warming things up a bit.
    Yeah, is that oil or coolant? I have been watching it pretty closely for the last week. The engine is always between 185 and 200 and the oil is between 180 and 200 at 'operating temp'. I have a 195f thermostat. I put a ford performance water pump in it when the engine was rebuilt, perhaps it is a little too effective.
    The graph was referring to water temperature vs engine wear - I posted it because the discussion included mention of a 160 degree tstat.
    Oil and water temps usually stay in a close relationship to the workload on an engine and the temperature of the engine.... There are oil coolers out there to help bring oil temps down, but in many scenarios (especially NA applications) an engine will be headed towards overheating and other problems before oil temps get "that" hot.
    At least that's what I've seen from running oil temp gauges along with pressure and water temp on a few of the dirt track cars I helped build.
    We didn't ever do anything fancy on our track cars. The cars we built ran in bursts that weren't that long and we found an oversized radiator with fans cooling it down in the pits did a good job.
    Crazy to think its even possible to run a 460 at high RPM for 10-15 minutes on a 100 degree day and have a shot at keeping it in a safe operating range, but we did. Some of the other Ford, PBO, Chevy, and Mopar combos we ran fared a lot worse actually. We tried lots and lots of the wall stuff.
