Results 1 to 7 of 7
    Default Engine Bay Harness Removal - Driver Side
    Hey all,
    I am swapping out my cut up 85 wiring harness with an stock non-hacked up harness. I got it out of the passenger side through the firewall easy enough but I'm not sure how to get it disconnected on the driver side. Do I need to pull the instrument cluster and drop down the steering column to get to the connectors or ???? Looking up from under the dash I don't see the connectors I need to disconnect at all.
    Thanks,
    Bill
    There are multiple connectors for the steering column and other dash items. Several are attached to clips on the pedal box mount that the steering column bolts to. Good Luck!
    Quote Originally Posted by IndyBill View Post
    Hey all,
    Thanks,
    Bill
    Its 4 or five plugs sitting behind the column and the few that go inside the fender for the tail lights and door chimes,easy take your time use some kind of lubricant to work them apart
    Sent from my SM-A530W using Tapatalk
    Quote Originally Posted by canadianmade2 View Post
    Sorry drop your wheel and drop your dash only way
    Maybe get something from this
    Thanks all! I did end up removing the dash because I also found that the heater core lid had been broken by a previous owner and duct taped to cover the hole!
    A win then,
