Results 1 to 7 of 7
    Apr 2010
    Portland, Oregon
    Default 1980 Fairmont Boxtop - $2000 (Tacoma)
    Not Running Project
    Solid 1980 fairmont project. Must sell due to lay-off.
    Only rust is a small hole in battery tray.
    -1993 roller 302 with 4 barrel
    -5 speed. Wc T5 from 1990 gt
    -All front suspension,brakes,steering box,from 1990 gt
    -8.8 traction lock
    -clutch pedals installed
    -new McLeod clutch kit
    -bbk headers
    -2.5 exhaust with flow masters
    -new dist with correct gear for roller cam
    -ac and air pump delete
    -Holley blue pump needs to be plumbed
    Only obvious parts needed are drive shaft fan and shroud.
    Price is 2k firm at this time. Low Ballers will be ignored. Seriously
    https://seattle.craigslist.org/tac/c...139993483.html
    St. Louis, MO.
    Yeah Baby.....
    Scotty
    Past Pony's.....
    Cool car
    def nicer than mine
    Whitestone, NY
    Older photos?
    No engine shot and no shifter sticking out of floor.
    Jan 2004
    Olathe, Kansas
    Quote Originally Posted by 87gtVIC View Post
    Older photos?
    I was just gonna say the same thing....
    Now stang-less.
    88 Cougar 5.0
    Whitestone, NY
    Rereading the ad leads me to believe it is just stuff that comes with the non running project. Basically you do all the work.
    FEP Member endub's Avatar
    Aug 2011
    Fayetteville AR
    I'd trade my wagon for it.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
