Results 1 to 8 of 8
    Default Compression with TFS 53cc heads
    hey all,
    I am looking at TFS TW 170cc ported heads with a 53cc chamber. They would be replacing 60cc GT40p heads on a 2000 mountaineer/explorer 5.0
    https://www.trickflow.com/parts/tfs-52515301-c00
    how much compression gain might I expect? Any reason I may want to steer clear?
    Theres a trick flow stage 1 cam in there at the moment, and a performer rpm intake, holley 650 carb
    Tony
    I’m not sure that calculator is accurate, it gave me 10:1 with my current set up, whereas FoMoCo rated it as 9:1, and with the TFS heads it’s showing 12:1 which seems just a tad high.
    I was using a zero deck clearance and -5cc piston dish, which is what stock was according to my research
    Tony
    You sure it has a 53 cc chamber? TFS says 61 on the 170. Mine spec'd at ~60cc when I measured mine.
    That’s what their website listed. I think there are two 170 heads , with different chambers. The one I linked was part number TFS-52515301-C00, the one with the 66cc chambers was TFS-52516301-C00
    Tony
    Oct 2017
    south-central WY
    If I understand that calculator, a negative value for piston dish is for domed pistons. I would think that if your pistons have valve reliefs, you should be using a positive value.
    FEP Member bkm's Avatar
    Jan 2016
    House Springs MO
    Quote Originally Posted by 4eyedblind View Post
    The 11r 170 heads are 53cc.
    10:1 sounds exactly right, according to Page 12 of the Ford Parts Interchange Manual, 1959-1970, By Paul A. Herd.
    The 283/284 tag J VIN code 4V 221/230/235/250 hp gross 302 4bbl engines for 1968 Fords/Mercs and 1969 De Tomasos all had 53.1 cc heads with that compression ratio, bang on it.
