Results 1 to 12 of 12
    Default 02 sensor holes on BBK H pipe
    so i switched to true duals on an 85.
    put a BBK H pipe on with no issues other than the 02 sensor holes.
    since its a carbed motor, no need for the sensors.
    what is needed to plug the holes?
    1985 Mercury Motorsport Capri Registry
    Official Pace Car of the Mercury Motor City 100 - Grand Prix IV
    www.Motorsportcapri.com
    Jan 2004
    Olathe, Kansas
    I just used some hex head brass plugs. Been so many years ago, I don't remember where I got them.
    Now stang-less.
    88 Cougar 5.0
    Hardware store should have those plugs
    Jul 2010
    Houston (Clear Lake), Texas
    I have the BBK x-pipe on my 85...can't remember it's been too many years back, but I know you should be able to find something at the local hardware store...
    HAD
    HAVE
    Grand Rapids, MI
    Thread should be M18x1.5. If you search for o2 sensor plug you should come up with some results.
    https://www.amazon.com/Oxygen-Sensor...08J99GQCQKSXP9
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    This is what I used on my BBK long tubes. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    1979 Mustang Indy 500 Pace Car
    Modified Mustangs Aug, 2006 Feature Car
    2016 Shelby GT350
    2015 F150 2.7 Ecoboost
    Get yourself an afr gauge and use one of those holes! I love having one in my car. I think it was 140 and included the wide range sensor. Great for trouble shooting, and in your case tuning the carb.
    May 2016
    Lake City Pa 16423
    Oil pan plug.
    I assume stock h-pipe would want to obviously have the same thread pitch
    Jan 2004
    Olathe, Kansas
    Quote Originally Posted by Str8sixfan View Post
    I would assume this as well.
    Now stang-less.
    88 Cougar 5.0
    Mar 2003
    Lowell, Oregon
    Yup - m18-1.5.
    I got two at my local fastner store and cut them down.
    The hex brass plugs always rattled in my car. Made me think a actual plug would need to be tapered like a NPT plug or something
    Theodore J. Garbera, 1985 Mercury Capri RS
